Originally Posted by Raysupra
its a intermittant problem... had it for the past two weeks.. haven't been driving the car... Ive been working on it trying to figure it out.. took alot of stuff apart. the fuses are good.. the motors ground is good... dunno about relays , the clutch sensors are completely disconnected and the car used to start up? and Im about 100% its something with the ignition/ wireing.. not sure what thou but its aggrivateing me... im tired of trying to hunt it down might just pay a shop to redo the ignition wireing.
Just shot in the dark... try reseating plugs and connections.. see if there's one that might be loose or worn... this would explain the intermitancy.. also with things electronic, if not supplied the right amount of power, they will act funny or not work at all.. so even if something isn't loose or worn, there could still be lack of power causing intermittant issues that will likely grow more consistant the more and more it's pushed.. however, none of this post I'm making now pertains to automotives... just electronics in general... good luck
