Originally Posted by MA70-1JZ
you want to keep it twin...then dont muck around!! Run a set of Trust TD05 (  h34r: ) or Trust TDO6 ( :blink: ) and laugh all the way to the dyno...more expensive then what you are looking at, but in the end a much better result..other than that, just get steel wheels put in your CT12a's and run 16psi all day long.
just curious if you have a link for the steel wheels for the c12 turbos?undecided what to do once back from deployment.
