The clusters are cross compatible. The only thing you'd ever have trouble with when swapping clusters is that the GE and GTE tachometers are different and require modification.
Have you replaced the 7.5A Dash fuse in the driver's side fuse box? Made sure all of the connectors in the back of the cluster are securely plugged in?
