i havent checked the fuse yet but could that really be the problem? and how can i tell the difference between a n/a cluster and a turbo cluster? the only differences between the two are there are more lines in between each indecated line and the redline is 250 rpms lower. but damn i forgot it has a boost gauge so its deffinately from a turbo model. do you know of anyway i can check to make sure the gauges in the cluster actually work?
oh btw thank you
Cusco front, Tein Rear coilovers
Massive DDP, 3'' custom catless exhaust, Tsudo muffler 4.5'' outlet, Apexi cold air intake, Act stage 3 clutch, ct26 turbo (stock)- 10psi
+300rwhp
"Not driving a car because its too nice, is like not fucking your gf so shes still tight for the next guy"
