Old 11-13-2009, 12:53 PM   #1
MA70-3.0GT
MA70-3.0GT's Avatar
JDM had the charcoal canister too.
As far as I can tell mine doesn't unless it's hidden, a different shape & plumbed from somewhere else, as the nipple that the vac supply is taken from on the USDM is non-existent (not blanked, just undrilled.). Anyway I think the lines are pretty much there or thereabouts, certainly not wrong enough to be a cause of the no-idle fault anyhow. Can't wait till tomorrow now so I can throw a gallon of juice in it & see if setting the TPS & fitting the recirc. valve back cures anything.
If not then I'll pull the codes again after it's run for a while & see what happens. Oh, and check the ISCV, EFI relay/resistor, rail pressure & cold start injector, plus the other bits I wrote down the other night to look at.
I'll let you know what happens either way, thanks for the help so far.
Cheers, Dan...
