Old 11-13-2009, 10:36 PM   #1
.Andrew.
.Andrew.'s Avatar
.Andrew. is on a distinguished road
Thanks Cre,
I got everything you said with a W58 trans tho and electric fans. For that igniter does it have to be off of a 7mgte. also is there any little parts that go for the GTE_(electronics, switches, relays, valves) My supra is an 1989 and the turbo motor i got is from an 89 :-) so the harness and ecu are most likely good ++
.Andrew. is offline   Reply With Quote
