Old 11-16-2009, 07:10 PM   #3
Originally Posted by .Andrew. View Post
Im going to see if i can get the high impedance ones from RC. The 7MGTE i bought has the fuel rail w/ injectors too. so if i cant afford the RC will those work?
Don't even bother looking for high impedance injectors. The GTE electrical system (ECU and harness) is built for low and low is the most common. Just get the low and make sure you get the resistor; You can get the resistor from any 7M-GTE or any pre89 7M-GE vehicle.
