Thread: wheel offset
Old 11-16-2009, 10:01 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
Bolt pattern PCD 5 x 114.3mm Offset 35mm-38mm Centre Bore 60 mm The larger the offset the more the wheel will sit under the wheel arch.. The stock saw-blade wheels are 37 offset. I did have a set of MK4 5 spoke with 50 and 45 offset not only did they look wrong I found the steering very twitchy. I now run with 18 x 8.5 Front and 18 x 9.5 Rears, offset 35mm. What ever you decide; make sure you have the correct bore or order the correct spigot rings. 60.10mm will fit perfect.
