lol
yes the supra 7mgte turbo will kick their asses :P
provided they haven't dumped $10,000 in their engine bay lol
there are quite a few vtec's here which are pretty damned quick but they are few and far between... well in NZ anyway lol
if you do the good basics like exhaust, intake, filter, boost controller etc you should have a fairly quick one
make sure you do the usual checks on buying a supra turbo as a head gasket failure is common due to the lack of torque from the factory on the head
just make sure when you start it if it's cold that it doesn't have a waterfall in the dash.. it doesn't have a consistent idle miss.. white smoke out of the exhaust when warm and make sure oil & water hasn't mixed and a compression check if you can be that cheeky with the seller hehe
but hell yea a supra will take on a civic
my best et on the 1/4 is 13.6 with 10psi.. exhaust, filter, bigger intercooler and 2 1/2 plumbing... so not really alot done and a good amount of power
good luck
