Car dies coming down from high rpm's
Hey guys, ever since I got my car, I've had a problem with it dying. Its worst when its cold but has happened when the motor is warm too. If I'm above about 2500 rpm and put the clutch in, the rpm's drop and it usually it dies. Sometimes it chatches itself but the higher the rpm's the more likely it will die. I can downshift and tap the throttle when im slowing down but I'd really like to fix this problem.
Thanks, any help is appreciated.
89 supra JDM 7mgte w/ R154.
