Old 11-24-2009, 04:45 PM   #2
BestSupra87
BestSupra87 is on a distinguished road
Default Passenger side window problem
I have the same problem with my 87. Tried connecting the battery directly to the pasenger window motor and was able to make window go up and down. So I figured the motor and regulator were fine. Must be electrical.
Read a couple posts here and looks ike it is probably the main power switch driver side. Wierd cause the driver window works fine. Still have not pulled it out, tho I heard they are hard to fix and you have to try buying a used/new one.
HTH
BestSupra87 is offline   Reply With Quote
