Old 11-25-2009, 03:19 PM   #2
MA70-3.0GT
MA70-3.0GT's Avatar
Not sure about the constant boosting thing as the turbo shouldn't be getting enough exhaust gasses to make any boost at low revs, perhaps the sensor has gone haywire? Or if you mean it's overboosting & getting fuel cut then the wastegate could be stuck (or the actuator failed), probably stuck after sitting so long...
As for the rough running, have you got any fault codes when you do the diagnostic check? (making sure the light works beforehand)
