In one drag/conversion magazine called ZOOM I read that you could fit the 1GZ-FE engine (stats below) in a Supra. Here's the stats:
1GZ-FE
Type: 4996cc EFI DOHC 48-valve V12
Power: 206kW@5200rpm
Torque: 481Nm@4000rpm
Gearboxes: floor or column-shift RWD 4sp auto
Bore: 81mm
Stroke: 80.8mm
Comp: 10.5:1
Can it be done? And if it can, would it be a benefit or loss in Grade A Toyota muscle???
P.S. The reason I am asking is that I'm not great with stats & I can't get a piccy of this engine (it's supposed to be rare).
h34r:
