I guess you're right, whatever happens I'm still having the car & whatever it turns out to be is whatever I'll fix.
Just one thing, I did a compression test last night (cold as that's when the problem seems worst, I'll do hot today) and all came back at 145psi except number 5 which was 130psi, exactly 10% so just about within "acceptable" range & not what I would have expected from such an apparently big leak.
I think I'll look into sealing products for the moment (such as K-seal, which is designed with bi-metallic engines in mind) and if the problem persists I may run something like that through the cooling system to try and stop further erosion of the gasket/head.
At least that way I can get some use out of the car & identify/correct any other issues before spending big money on the motor. (If I have to do the HG I'll probably get the head & block lapped & go with the MHG solution with ARP bolts, that way it should last a bit better & I can tune without worrying too much...)
