Old 08-21-2005, 05:51 AM   #7
Guest
Guest
Posts: n/a
Originally posted by SuperSupra86@Aug 20 2005, 07:17 PM
Well with Toyota they sent the TT into a perfectly smooth sequential boost.....A single larger turbo tends to get more Torque in low ranges where as the TT you have higher range Torque and HP due to Turbo Lag, etc....I've seen some single Turbo MKIV people have modded and they are incredible beasts off the line, but generally the TT set up tops out at a higher Max Speed...Just my two cents on the set ups i've seen
Actually you have it backwards, A single will give you less low end power and more grunt at the top end. The stock twins will spool quicker so you get tourque lower in the rpm range.
And single turbo upgrades will make more power, more efficiently than the stock twins will.
