Old 12-03-2009, 05:04 AM   #3
Green7mgte
Supra Forum Moderator
any detailed instructions on how to change the wire lever inside the car. I was talking to a buddy of mine and he said to just grab hold of the wire cut it and make it taught again.. so the picture I'm getting is to disconnect it were it connects to the lever beside my seat. cut it to remove any slack and re-attach it. is this a viable solution? would it be ezier to do the same operation in the rear of the car were the lever wire connects to the actual trunk latch?
thanks
(also grab the wire and don't let it slip down the tube or your never going to get it out again.)
http://www.toyota-supra.info/forums/...ase-cable.html
found this. basically the same idea.
