Old 12-03-2009, 04:05 PM   #4
MA70-3.0GT
MA70-3.0GT's Avatar
Oh, one thing I did mean to mention. When I came to remove the cambelt I noticed that it's been running towards the back of the cam pulleys i.e. right on the back edge, and when I look down at the oil pump pulley it's actually been running OFF the back of this by about 1/8".
What would cause the belt to run to the back, tensioner bent? (all new kit in there from previous build) and why is the oil pump pulley not dead in line with the cam pulleys?
Also is the 7M-GTE an interference engine? (if the belt broke would I bend valves?) If not then I'll re-use the belt as it's a Gates item & has done nothing, otherwise if a breakage would wreck the valves then I probably won't risk it & pull the crank pulley off now...
Cheers, Dan.
EDIT-: So it seems there's no "magic" easy way of pulling the turbo off the manifold then, just struggle with the 4 bolts? I've got 3 of them but the lower front one is a complete PIG to get at isn't it?... Oh well, I was going to cheat & just loosen the manifold & turbo oil pipe together & tie the assembly back out the way, but the heat shield bolts on the mani' won't undo with an open ended spanner & a ring won't fit with the turbo in situ. Oh well, I'll just have to do it properly
