Old 12-03-2009, 05:02 PM   #1
MA70-3.0GT
MA70-3.0GT's Avatar
Default Digital dash boost gauge...
Anyone one here got the digital dash on their car? If so, where does your boost gauge go up to? Just had a thought, I noticed when I drove my car home that when you floor it & the turbo spooled up (I just HAD to do it once!!!) the gauge flew straight up to 3.5+ & I don't know how the hell mm/hg equate to PSI, there's no reference in the TSRM, only to kg/cm, kpa & psi...
EDIT-: I'm getting something mixed up here, I was sure the gauge said mm/hg but 3.5 mm/hg is 0.06psi, 3.5 in/hg is 1.72psi and if I misread it & it meant 35 then we're talking either 0.68psi for mm/hg or 17.7psi for in/hg...
Think I need to do a little checking of my dash 'cause there was definitely more than 1psi & no fuel cut to suggest 17psi, although the latter figure would certainly explain the BHG!!!
Anyway, I'll check that site again once I've found the proper unit of measurement & find out for sure. For anyone else, here's a link to what I think is quite a useful site for conversions...
http://www.engineeringtoolbox.com/pr...ter-d_569.html
The only thing that comes close to a 3.5 units when converted from 4.8psi (the low boost figure for an AT car) is metres of water "m/H2o" & I can't see why Toyota would use such an obscure unit of measurement in their cars so there's definitely something amiss!
