Originally Posted by MA70-3.0GT
Contrary to popular belief no 4-stroke engine "needs" back pressure, for reasons which I'm not going to bother going into lest I open a whole nasty can of worms...
Anyway, all I'm saying is that removing or gutting a cat should have no effect on your turbo's operation. For the benefit of people who haven't seen your other thread, what is the actual problem you're having? Lack of power?
If so (and I'm guessing you gutted the cat because it was damaged already?) the escaped material from inside the convertor may be blocking the exhaust further down, it usually gets trapped in the back box. Pulling the whole system off & cleaning it out is the solution to this (or ideally replacement).
Let us know what the actual problem is if not that & I'll have another stab at it.
I agree
check the back Box and see if your missing converter pieces reside inside
