Thread: spare tire?
Old 12-04-2009, 08:32 PM   #12
Add a DS loop or cage or whatever you want to call it... if it grenades you don't want it hitting the ground and tossing the ass of the car 3' in the air or, worse yet, have the broken DS cone up through the rear floorboard. I recommend steel over aluminum. The saving from either is HUGE over the stocker but between those two it's only a couple pounds and the steel is more resilient to the type of stresses a drive shaft goes through.
