You're getting close now, with the turbo off & inlet mani' out the way you're on plain sailing from here. Just make sure you undo the head bolts in 3 passes & in the correct order (opposite order to tightening sequence).. I'd say maybe an hour until the head's off now.
Oh, make sure the drain plug's out of the block too or water can get into the oil passages!
As to the oil, it's normal to have some oil in the intake but if you think it's excessive (only excessive if the car's visibly blue smoking IMO) then you might want to check the turbo oil drain isn't blocked with carbonised oil caused by shutting off without warming down. TSRM has specs for measuring turbo shaft play too.
Best of luck & let us see the carnage of the old HG when you're done!
EDIT-: Don't Black MA70's just look the dog's danglies compared to any other paint job? It's the ONLY colour for a big GT car like this IMO, and if I could respray mine the only thing I'd change is I'd go from Toyota's plain Black to BMW's "DiamantSchwartz-Metallik"
EDIT#2-: Re: Weather, YOU
LUCKY BASTID YOU!!!!
hahaha, hammering it down here...
