Old 12-06-2009, 06:11 PM   #11
MA70-3.0GT
MA70-3.0GT's Avatar
no no no not the oil drain, the block coolant drain bolt (see the handbook p142 IIRC, or the tsrm) so that the remaining coolant in the block doesn't spill over into the oil passages & bores when you lift the head.
Oh & don't zip tie or fold the timing belt in any way as it can get damaged. There's no need to keep it on the teeth if you set the motor to TDC before you remove everything (again see the tsrm for locations of timing matchmarks, it's dead easy & failsafe for getting it back spot on, plus you'll probably want to turn the engine while the head's off so you can decoke all the pistons properly).
I'm gonna sing & do a rain dance for ya now! lol. Let's see if it really does have a metal HG..., maybe he meant "Moron-fitted Head Gasket" if it's gone already!!!
