Old 12-08-2009, 08:52 AM   #11
riojohn
riojohn is on a distinguished road
HI,
Most 240sx’s come equipped with what is called an open differential. An open differential is designed with four gears set inside a casing that is rotated by the driveshaft. One gear connects to each output shaft and the remaining two gears connect to a center pinion and rotate in opposite directions perpendicular to the rotation of the casing.
In this manner, power can only be sent to one wheel at a time because the pinion gears counter the rotation of the casing for one output shaft at a time. In short, one wheel gets power while the other one coasts.
Thank you....
riojohn is offline   Reply With Quote
