Originally Posted by blackdemon93
i am converting a 93.5 toyota supra to a jdm vvti aristo swap.
i did this before on another supra which wasnt the vvti engine and didnt run into any problems. Well here is my problem i when i sit the engine in the bay the motor is twisted.
i used the n/a mounts and brackets, any advice will be helpful im going crazy!!
Have you tried the Aristo mounts? Worst case you may need to get a custom mount fabbed. If the Aristo mounts don't work, I'd recommend you pull the vvti engine and carefully measure it's mount locations and compare those measurements to the n/a 2jz-ge mount locations. Wish I could be of more help, but I haven't done this swap myself.
Please keep us informed - post back here when you've found or made something that works. Thanks in advance!
