Originally Posted by MA70-3.0GT
Just a quickie, not sure where you took the car for the rad/ job, but did you make them aware of the bleed procedure for this car? i.e. lifting the front way in the air...
This explains why after my thermostat and hoses were replaced during my flush and also after this radiator repair, I had to add more coolant to the system after driving it just a little bit... I was wondering about that..
Cre: you mentioned something about running your heater... is this a normal step in the process? what if my heater's not working cause I have no water in the heater hose? Last I cracked that open, it had nothing more than a mm deep puddle about 2 cm long and 1cm wide..
