Old 12-09-2009, 12:30 AM   #4
Please do be aware/keep in mind that the auto's radiator also has a transmission cooler built into the lower end tank. A replacement will most likely cost more than one without. You may install a separate transmission cooler however allowing you to use whatever radiator you wish.
