UPDATE:
I phoned Toyota Garage today;
(1) they didn't do pH test on the water reservoir,
(2) they didn't do a compression test on cyclinder heads.
They did do pressure test on the water/coolant, results;
(1) it didn't hold any pressure,
(2) there is no water getting to the engine at all.
If this were the case the engine would not be working.
Checked the oil again, it is clear as day, no bubbles.
After I come home from work today I am going to feel the water reservoir to see if it is warm, that should tell me if the water is circulating and therefore getting to the engine, YES?
