I would go with a B&M cooler (I've got a large one as my engine oil cooler and another for my power steering), Perma-Cool should be fine (I've never used one though)... There's Canton who makes some excellent components, but their oil coolers look to me to be just rebadged B&M coolers (I don't know that that's the case but they do look identical). As I mentioned before, you need to figure out where you're going to mount the cooler and then measure to find one that will fit; Make sure you keep in mind that you also need to be able to route the oil hoses to it.
http://www.summitracing.com/search/?...20cooler&dds=1
If you're looking at a long, narrow space (like along the top or bottom of the bumper support) look for a "rail" style cooler.
With the oil lines I'd recommend replacing the stock lines completely, not just extending the them; Any barb used to extend them will most likely add a bottleneck. It's not the highest flow system though, so extending will undoubtedly be fine; It's just not my preference.
