Old 12-12-2009, 09:09 AM   #22
Okay, a thermostat isn't needed (not for the tranny cooler). As long as you mount the cooler somewhere with good air flow you do not need a unit with a fan. The fan will be needed if you place the cooler in a location with poor air flow such as behind the fog light.
I can't emphasize enough that you need to plan the placement and routing very carefully... it can be a pain. Have you thought this out already? I'd like to know what you've come up with.
