The housing means next to nothing... the concern is always wiring. You cannot supply enough current to a ballast through the stock wiring... People have tried and it NEVER works... the wiring gets too hot, the ballast cuts out a (if it ever even manages to come on), and fuses blow.
Wiring up a relay is a standard thing... easy to do and worth the trouble even if you're still running sealed beams (better lighting can be had from just better sealed beams or regular H4s). Do a search for Daniel Stern's headlight rewire articles.... He's published a great deal on the matter.
