I'd be inclined to suggest that the cold start injector may be blocked/disconnected, the time switch may be dodgy or something similar.
The tsrm is the first place I turn now for any info I'm after, here's a link to the csi page (the time switch is on another page which you can find by hitting the "section index" button, then it's about 3" from the bottom of the index, page FI-112) http://www.cygnusx1.net/Supra/Librar...ection=FI&P=77
I'd check the injector itself first as they can simply be blocked with carbon deposits
Or I guess the idle air valve could be mucky too, although this would usually manifest itself whether hot or cold...
