Aye stock is bolt, I wanted a stronger hookup but ended up using the stock bolt up... But what I meant about the bar was you don't need it for the frame to stay sturdy, but yes it does save your life ;p Which is why instead of ripping it out I had a lighter one made! Moved the battery to the back as well, you'd be amazed at how different just those two things made the front of the car feel, more response less understeer.
