no start after rebuild
ok I have been on this forum for months now. I just finally registered because this is an issue I have not found a suitable solution to. the car was givin to me by my good friend of 20 years. its a 91 turbo. the car lost a bearing and was parked 2 years before I started on it. I pulled the motor and got a low mileage long block, tore it down and completely rebuilt it with good stuff, added a header and garrett t04e turbo and hks downpipe, hks evc pro, hks 2mm hg, arp head bolts, arp rod bolts, high performance piston rings, custom made wastegate and matching bov, and greddy turbo timer. power steering, ac, and clutch fan deleted. everything is installed correctly. I used vacuum diagrams from this forum and also the tsrm.
the car will not start. triple checked timing, rewired cas, and checked for fuel pressure. cranks but will not start. also tried resetting the security system by opening all doors, hood, liftgate, and lock/unlocking all doors. no dice. check voltage at coil pack, igniter, and found them good. has new plugs in it as well. have gone threw every check that I could find on this site and others without success. there is also no spark which obviously why it wont start (im guessing). so there is where I need to start. but how?
