Bill UK covered it well in pictoral form here:
http://www.toyota-supra.info/forums/...on-sensor.html Those three items set the mechanical timing, then you tighten the timing belt tensioner pulley (do NOT over torque it!!!), then you set the ignition timing with the timing light.
