When I lived in Temecula I usually had to go down to the pick a part in chula vista for anything supra related. You can likely find a motor there, but I'd strongly suggest rebuilding it as there's no way to tell what has happened to it. You could also try the Ecology salvage yard off of highway 76 in Oceanside. In either case, that would be an affordable way to get you an engine that's rebuildable if yours is scrap. Other than that you're looking at a place like Driftmotion (like cre suggested) or a jdm importer (usually somewhere in LA), but once again you should rebuild a jdm engine as well.
