Originally Posted by suicidal
check and see if you put it in the same way it was before. even if you move it one slot over will throw off the balance. i found this out on my s10 when i did u-joints.
Ditto. If your off just be one, you feel the vibration. That's why it's usually good to mark it with liquid paper or something like that so it goes in the same way, on the same mark.
