Originally Posted by oregonjoe
Once the Intake is in place you can place the main wire harness on top and run the connections for the Starter, VAC switches, Transmission Switch, Knock Sensor, and EGR temp down through the runners.
Attachment 2369 Attachment 2370
The connectors are color coded so it’s not too hard to match them up. You can reach under and attach the Knock sensor and VAC Can connection under the runners.
Attachment 2371 Attachment 2372 Attachment 2373
is this the same wire? and where does it go?
