Toyota do list the radiator drain cock as a separate item Link, so I would assume you could purchase one from Toyota UK, that is of course your rad is a stock rad. As far as fitting I can only guess it would be similar to a Mitsubishi rad; you unscrew it all the way and then screw it back in by a quarter of a turn and then pull it out. The best way is to buy one, which would give you a good idea how they fit.
Reason: Changed fraction into text (quarter)
