Old 01-02-2010, 02:00 AM   #4
mirage83
And yes, the pads are what 1/8" think new?
About right, thin enough to shock the hell out of me the first time I got in there to replace the rotor and brake pads on the rear. I was in panic mode trying to find replacements until someone on a forum mentioned that they're thin to begin with. After that I looked closely at mine and found that they were virtually unscarred, probably seldom or never been engaged.
Originally Posted by Cameroonski
Ok. So it's a partially siezed E-Brake. Right? Whats the best way of fixing this?
You gotta find out exactly where the problem is first. Pull the rotor and inspect the mechanism itself, make sure the cable isn't pulled tight and binding somewhere. It might be something really simple, won't know until you find out precisely what's going on in there.
