Originally Posted by cvbikeguy
I know I should know this but. Where's the fuel pump fuse? And what do you mean pull the plugs. Thanks for your help. You were my main thread in this build I was trying to follow
Remove the spark plugs so you can crank without compression - allows oil to pump through out the engine without draining your battery. Better way to get it up to the CAMs. Most people don't do this because its too hard to get all the plugs out.
