Oil PSI
After my rebuild the OIL PSI did not read at all while cranking and took about a 30 seconds after startup to register. Should come right up after that.
If car starts, runs rough, and lacks power - it is ign timing or valve timing.
Car should warm up so ECM dosn't choke down the IAC before you do final timing adjustment. Just keep the car running via throttle till warmed up and then check timing with light on crank.
