Old 01-05-2010, 08:56 PM   #13
Green7mgte
Supra Forum Moderator
ill try it out. off to work atm
Time elapse:24 hours
i took off the parts and began cleaning. I re mounted the rotor and placed my rim on. pushed it back as far as it would go removed my rim and secured the rotor with lug nuts.
same problem. I apply the caliper over the brakes and the opposite end of my rotor pops out not allowing clerance of the lower caliper bolt to slide into position. now either im not getting 1mm clerance on the rotor to the hub or I don't know what else. Im seriously at my end with this.
I heard that the later production 92 supras may of had there brakes changed to the newer 93 model. can anyone confirm or deny this. I could be wrong.
I bought a new rotor and still have the same problem of not enough clerance. Im taking my pads back and getting something from NAPA.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
