clutch pedal problem
Well today I went to start up my supra and something happened,
Usually it starts up almost everytime unless its cold. not today and i'm missing work because of it so any advise would be fantastic!
ok, I unlocked the door, sat down, put the key in the ignition, pressed down the clutch pedal for start up.(this is where things got odd) as I pressed the clutch pedal all the way down I think I heard a small kink. naturally I took my foot off the pedal and it only poped back about half way as if stuck in mid engagement. i felt around by the pedal and nothing was loose. the problem im having is the clutch pedal seems to be stuck there and wont pop out like usual. I can give it a small pull and it will pop out all the way. pressed down, pop back halfway, small tug and it pops all the way out like usual. I havn't started the car seince this happend a few hours ago.
clutch pedal spring, cable or hydrolic? cylinder fluid?
has this happened to anyone?
I've had it happen to my old Honda CRX, clutch cable came loose, tightend the adjusting nut and bam fixed.
86.5 mk3 supra 7mgte r154
