Old 01-09-2010, 01:47 AM   #3
Busted Knuckles
Busted Knuckles's Avatar
Simple. Find the neutral safety switch, cut the wires at the connector, and splice together, completing the circuit.
The neutral safety switch was on the passenger side of the transmission with a three wire connector. The two prongs that are parallel to each other are the connectors for the safety switch. One wire should be black with a blue stripe, and the other black with a white stripe. Cut these two wires and splice them together. This from the TSRM. There used to be a sticky for it.
