I already answered that.... ONLY THE AUX FANS.... sheesh.
Personally, I don't recommend electric fans. Flex fans place as much resistance on the engine as the additional load on the alternator does and are less likely to fail; Not to mention that it seems MKIII owners have a lot of trouble getting electric fans installed properly, for whatever reason.
One final note, if you do go with electric fans the A/C aux fans' thermostatic switch does not close until about 225?F; this is too high for a primary fan and is a likely cause of many of the failures owners have seen.... well, that and an amazing wire a fan correctly.
