That would be a flex fan. At higher speeds the blades flatten out reducing resistance while still moving more air. You MUST use a fan clutch built for it though, the stock fan clutch will spin it fast enough to send the blades out through the hood or through a coolant hose.
IMO, you should upgrade your radiator before switching to either setup.
