I highly recommend an electric fan
I've run mine for years , a good fan comes with it's own thermostat to turn it on and off and you will gain HorsepPower . put it behind a high performance aluminum radiator and you've got one Cool Supra . driving around on back roads just cruising i run @ 160 degrees a little cool but making heat in a turbo'd supra is not difficult . an accurate temp gauge is a must . you want to talk about squeezing every bit of hp out of your car this is one area to look at.
oh btw i didn't have any electrical 8-) issues i.e. draw on the alternator
Reason: added info
