Each transmission uses a different drive shaft. You're not going to be able to use this one with either of the MKIII manual transmissions.
Just a note for those reading:
Another option, is to have the OEM drive shaft rebuilt with lighter tubing... still need a carrier bearing in that case, but there may be some inexpensive options available that way.
