Originally Posted by 916MKIIIx2
I heard that sometimes if the rust is bad enough and it builds up over a long period of time it could ruin the lower end of the engine... don't quote me on it but it sounds legit ;p
I'd flush it ASAP, or atleast drain the radiator and put some fresh coolant in there.
Also if the total repairs for the "engine" are more then $1500, you may want to look into a 7MGTE complete engine from suprastore for $1500
im only spending like 700 or so its 350+ to rebuild turbo i spent like 250 on gaskets and 100 on random stuff ill have to buy while putting back togeather.
are suprastors engines rebuild or just sold the way they were found?? im kind of skeptical iv heard they were a good site but i dont even get to see what the engine looks like.
im almost ready to put the top end back togeather all i need is over sized oil drain plug wasshers and my spark plug wires that have yet to come in... should be here on the 21st
ohh and note to all oreily autoparts sucks dick! they told me all the parts i needed were dealer spacific( plug wires, and vacume line tube with a valve on it) so i went down to advanced autoparts and they had every thing just needed to order it due to the car being 20 years old.
anyone have sugestions on a intake system for the supra turbos? the whole stocl box on mine is in pretty bad shape it was sucking things into the turbo i could see pits and bent blades in the turbo along with coolant running down the intake tubes
