Green & Cre,
I promised you two I'd give an update when felt spiffy enough to work on my supra again.
Update -
Ohmed all sensors, relays, resistors, coils, etc all read within spec.
Compression check all cylinders @ 151-152 lbs.
Fuel pressure & volume fine.
Last thing I did before I quit for the evening was unplug to injector top to the #5 cylinder, metered it to see if a voltage signal was hitting the injector while cranking. No signal. So something is causing the injectors not to fire. I'll try to trace that down tommorow or tuesday if I feel up to it. Already feeling stiff (old sucks!)
